Tunercat ?s
Old Jan 29, 2004 | 10:06 PM
NeverFastEnough's Avatar
Tunercat ?s
Is the tunercat software as good as the LT1 editor and if so were do I get it, how much is it, and I have a Hypertech. Will that help me figer out what port I have?
1 more ? Is tuner cat more user friendly than the editor(I hope so)
NevFstEgh
Old Jan 29, 2004 | 10:59 PM
To get you started, you can take a look at Tunercat here.
Old Jan 30, 2004 | 11:20 PM
Old Jan 31, 2004 | 02:21 AM
brokenz's Avatar
I hardly ever here of people frying their PCM with Lt1edit. I can't say the same of Tunercat though. Take whatever meaning you want from that. All I know is I've reflashed my PCM more times than I can remember with edit and I've never had a problem.
Old Jan 31, 2004 | 02:39 AM
LPE Z convt's Avatar
Is LT1 edit a better program than tunercat? My car has been reflashed with tunercat alot of times and no problems.. I thought about geting tunercat but don't know which would be better....
Old Jan 31, 2004 | 04:31 AM
stevil's Avatar
TunerCat can program everything that LT1 Edit can, so it is "as good" in that respect.
The software is $90 or so I think, including the LT1 file you will need with it (TunerCat is $70, and they offer definition files for $20 each which can program different GM vehicles). The software was cheaper than the cable, which cost me $95.
Your car is a 1995, so you have an OBD-I computer with an OBD-II port. Sort of complicated, but 1993-94 F-bodies have all OBD-I, while 1996-97 have all OBD-II. The 1995 cars are mixed up for some odd transition reason. So even though you have OBD-I, you would need an OBD-II cable. Check out this site for cable info.
I've flashed my PCM many times with TunerCat, and other cars, and never fried anything. There was a beta version of TunerCat for Windows that might have caused some problems, not sure... I've been fine.
I do think LT1 Edit is easier for the beginner, more user friendly. But once you know what to edit (and that is important) then it doesn't matter what program you use, you just go to the proper table and punch in numbers.
In anycase, I see no advantage to the overpriced and VIN locked LT1 Edit, take whatever meaning you want from that.
TunerCat needs to help out the LS1 guys, they're getting raped on LS1 Edit ($550 I think).
Old Jan 31, 2004 | 06:43 AM
brokenz's Avatar
Also keep in mind that there are many tutorials and a real good mailing list that you can get for support if you are running LT1edit.
Old Jan 31, 2004 | 09:23 AM
You can learn programming tips from the mailing list, then use Tunercat to save some money.
Old Jan 31, 2004 | 07:42 PM
brokenz's Avatar
Agreed on that point. But it's not enough of a difference in price to justify not getting the program that has a better reputation in my mind. I used to hang out some and read the computer diagnostics/ programming forum here. A common topic was people frying their PCM's using Tunercat. About the only times you'd see that with Edit was when someone was doing something obviously wrong. There was even a thread of people comparing how many times they had fried their PCM with Tunercat. Now maybe that was because of a few bad revisions. How often has Edit come out like that though? Same thing with the Lt1edit mailing list for a long time. Unless you keep spare PCM's laying around then you are down when that happens. So I figure why not use the better (as far as stability) program?
http://web.camaross.com/forums/showt...hreadid=219200
Version 1.97 had a bad problem with EE files so be sure you have the latest software.
Funny I don't remember people having those kinds of problems with Edit.
http://web.camaross.com/forums/showt...hreadid=216732
What did he do? Does TC verify the checksum before you program? You should do that on your own anyway but Edit rechecks it for you before it'll let you screw up something.
Old Jan 31, 2004 | 07:45 PM
brokenz's Avatar
I got a little off tangent there. My specific point is that the list is geared for people running Edit. I've been off the list awhile (decided to take a break since there wasn't alot of new info coming from it at the time) but I did get tired of people asking how to do something in TC. The terminology has enough differences between the two that people were having to pull teeth to get their TC questions answered.
MDZ28
11
Sep 24, 2015 09:15 AM
whitehooptie
Jul 22, 2015 10:25 PM
jdelaprida
Jun 27, 2015 08:30 PM
2QUIK6
11
Dec 11, 2002 09:38 PM
1BadBrd
Aug 6, 2002 07:04 AM
