Tunercat is it best programer?
Iam going to buy tunercat because you can use it on other car besides your own.Is it a easy program to learn? And do you start with a basic stock program and go from there.thanks for any advice.
Re: Tunercat is it best programer?
Yeah it is really easy to learn, just looking though the tables to see what does what really helps you figure out what is going on in there...
Yeah you pull your stock file and then you can start tweeking it from there just save it to a new filename so that you still have original to fall back on if your tweeks are not working as expected...
whitehooptie
Aug 10, 2015 07:02 AM
