What springs and retainer package should I use?
Old Nov 23, 2005 | 08:39 PM
Z28WannaB's Avatar
With the cam listed in sig what should I use, anyone have any link to any sites that are selling a combo that will work for my cam?
I am getting an LT1 block here right quick. And I want to have all the pieces for the full engine come january.
xe 218/224 .495/.502,
I will be using 1.6RR with that cam.
- Z28WAnnaB
Old Nov 23, 2005 | 11:25 PM
3gc's Avatar
3gc
Re: What springs and retainer package should I use?
Comp Cams lists recommended valve springs and other parts for each cam on their site. http://compcams.com/Technical/Curren...ML/198-199.asp Looks like you should go with the 983 springs. I suggest CCA-983-kit from summit, it's what i'm planning on running in my car when i put a cc305 in. The kit comes with the springs, retainers and locks, for about $25 less then if you bought it seperate.
Old Nov 23, 2005 | 11:54 PM
Z28WannaB's Avatar
CCA-4753 shims
CCA-501-16 seals
95chwagon
May 27, 2015 09:53 AM
Red_94Formula
Jan 22, 2015 12:17 AM
Black Sunshine/ 00SS
Sep 11, 2002 07:01 AM
