Tune up time!
Old May 21, 2004 | 01:55 PM
94NDTA's Avatar
Tune up time!
I have a 1994 Trans Am GT with 25K miles. I allready had the oil changed about a month ago. I have NEVER Flushed my automatic Tranny, coolant system, or my rear end. I also have never ran any type of fuel system cleaner through it (the previous owner might have.) I have a 3 year old fuel filter, and a 1 year old PCV.
Here is my check list, tell me if there is anything I can add to this, or if I am missing something.
PCV
Fuel filter
Transmission flush (with gasket and filter)
Coolant flush (new thermo and water wetter, which was free!)
Power stearing flush.
K&N cleaning
Differential fluid (with slip additive)
Butterfly cleaner (what is a good brand?)
Injector cleaner (chevron)
Anything else I could be missing? The tires can't be rotated, and I have never checked the brakes, but they don't squeak at all.
Old May 21, 2004 | 02:06 PM
Patman's Avatar
Brake fluid flush
Plugs
Wires
Coil
Old May 21, 2004 | 02:20 PM
LT1Squirrel's Avatar
O2's
Old May 21, 2004 | 02:38 PM
94NDTA's Avatar
I forgot to mention I have new plugs and wires allread for my header install. Any links on how to do a brake fluid flush? How do you check the O2's, just visually?
Old May 21, 2004 | 03:50 PM
ram air camaro's Avatar
clean your throttle body. that might help if it's never been cleaned.
Old May 21, 2004 | 11:03 PM
if the O2's have never been changed just change them
Old May 21, 2004 | 11:29 PM
#7's Avatar
what?
O2s and coil @ 25K. Am I missing something here?
Old May 22, 2004 | 01:40 AM
94NDTA's Avatar
I was thinking the same thing, why would they go bad so early? Also, I allready had TB cleaning on the list.
Old May 22, 2004 | 09:03 AM
yeah....but theyre still 11 years old
Old May 22, 2004 | 07:15 PM
"White Knight"'s Avatar
sometimes leaving a car sitting is worse than driving it In my personal opionion i would not change the O2's unless you know they are bad.....they should still be good IMO.
DirtyDaveW
Dec 1, 2016 05:37 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Jazsun
Dec 29, 2014 12:14 PM
