tune needed for new injectors?
Old Oct 10, 2008 | 09:54 PM
firstlast's Avatar
if i put in my new red tops now will it run fine untill i get my tuning software?
Old Oct 10, 2008 | 11:44 PM
mrmint69's Avatar
Get the tune first!
Old Oct 11, 2008 | 06:37 AM
If you change the size of the injectors without telling the PCM the new flow rate, its not going to run right. The PCM can make limited corrections in closed loop, but when you go WOT with oversize injectors its going to run extremely rich, possibly enough to damage the engine by washing the lubrication off the cylinder walls.
Old Oct 11, 2008 | 06:44 AM
gatorhead's Avatar
I agree 100 % with Fred!
Old Oct 11, 2008 | 09:52 AM
firstlast's Avatar
ok thanks
Old Oct 11, 2008 | 10:19 AM
LaredoZ28's Avatar
Dont run the car much with out a tune. changing injectors hurts you with out a tune. a friend of mine had 42lb injectors in his car and didnt tune it and ended up washing out the piston rings. now he has to rebuild the motor.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
