Tubular K member?
Old Dec 10, 2003 | 09:25 PM
  #16
BES-383's Avatar
Bought mine used with the lower A arms, adjustable drag shocks, and Ls1 brakes for $250.00. This is a P A K member. Only took 2 hours to install. You can tell by the picture how much more room it gives you from the bottom end.
Old Dec 10, 2003 | 09:30 PM
  #17
klbjoc's Avatar
Originally posted by BES-383
Bought mine used with the lower A arms and Ls1 brakes for $250.00. This is a P A K member. Only took 2 hours to install. You can tell by the picture how much more room it gives you from the bottom end.
Thats a hell of a deal. I looked for a long time for a used one and couldn`t find one, so I had to buy new. Your whole setup cost about half of what my lowef a-arms cost
Old Dec 10, 2003 | 09:45 PM
  #18
RCF925's Avatar
It's 100 lbs. if you do the shocks, springs and lightweight brake set-up as advertised with BMR, Sorry I didn't post all the info
Old Dec 10, 2003 | 09:52 PM
  #19
M93Z's Avatar
BES-383 nice photo, does anyone know if the PA K-member is designed differently than the BMR? The reason I ask is the BMR K-member will not work with my A S & M headers. [It interferes with the left side collector.]
Thanks.
Old Dec 10, 2003 | 11:46 PM
  #20
Camarocks's Avatar
BES-383, that looks sharp!
Can I do this tubular K member with a stock LT1 if I just want to lighten up my car some?
Old Dec 10, 2003 | 11:53 PM
  #21
OBE1 95Z28's Avatar
The tubular K member lightens up the front about 25 lbs and greatly increases access to plugs and wires.
The stock rag joint looks like a piece of fiber reinforced rubber. Heat fronm the exhaust wipes it out and add play to the steering.
My research on this board showed the BMR to be the best piece so that's what I bought. If your car has high mileage, you may want to look at replacing the upper/lower control arm bushings and ball joints at the same time. I bought the ES poly bsuhings and Moog ball joints/tie rod ends.
Old Dec 11, 2003 | 07:25 AM
  #22
RacinLT1's Avatar
i have a PA racing K member that will be going in this winter. either piece is good. Also the fact that the PA unit was free didnt hurt it's standings in the decision.
i went with PA because at the time the BMR was a new piece,and had issues with hooker LT's hitting the kmember,they have since fixed that.
Old Dec 11, 2003 | 08:50 AM
  #23
BES-383's Avatar
Yes you can.
Old Dec 11, 2003 | 12:03 PM
  #24
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
I went with BMR's package. Just the access you gain from under the car is worth it.
Old Dec 11, 2003 | 12:48 PM
  #25
MentalCaseOne's Avatar
I want a Rag Joint kit!!!
butt butt butt I also saw this in their website......
SOLO II Street Modified 1996 Camaro SS << 96 SS?
I swear I thought the SS wasnt made till 97!!
Marvin
Old Dec 11, 2003 | 02:11 PM
  #26
CamaroBoy96Z28's Avatar
Marvin
They were available in late 1995 as a 96 model. Camaro SS was not available after 1972 until the end of 1995.
I do really like that rag joint kit though. My steering does have some play in it plus that black looks so much nicer than rusted metal covered with a black plastic shield.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
football4life
Oct 4, 2015 07:48 AM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
