Tubular K member?
Old Dec 10, 2003 | 09:55 AM
94 CAMRO Z28's Avatar
Tubular K member?
How hard is the install of one of these things? Also how much weight do they save from up front? I would assume the car would be easier to work on after getting it in there.
Aaron
Old Dec 10, 2003 | 06:03 PM
Anyone?
Aaron
Old Dec 10, 2003 | 07:37 PM
OBE1 95Z28's Avatar
Justed helped my friend install one in his 96 TA. We used an engine hoist and a happy hooker to hold the engine in place while we swapped the cross members. Very straight forward (installed a BMR unit). You'll need an alignment when your done. Good time to install a rag joint eliminator to tighten up the steering too.
Old Dec 10, 2003 | 08:16 PM
Teal96TA's Avatar
What in the world is a rag joint eliminator????
Old Dec 10, 2003 | 08:24 PM
Xride's Avatar
I want to know that too.
Old Dec 10, 2003 | 08:27 PM
klbjoc's Avatar
I would also just go ahead and pull the lower a-arms on each side when you install it. makes it alot easier.
You will also have a bunch more room to get to plugs and routing your wires with the tubular k-member.
Kevin
Old Dec 10, 2003 | 08:31 PM
anaik's Avatar
http://www.unbalancedengineering.com/Camaro/Rag_Joint/
Old Dec 10, 2003 | 08:53 PM
RCF925's Avatar
You save about 100lbs weight with the tubular K-member
Old Dec 10, 2003 | 08:55 PM
Camaro_Maniac63's Avatar
Make that more like 35-40 lbs.
Old Dec 10, 2003 | 08:58 PM
klbjoc's Avatar
Thats more like it, and if you get the lower a-arms, it`s about another 8.
Old Dec 10, 2003 | 09:05 PM
pillagenburn's Avatar
how strong are tubular k-members? acceptable for street use? can they not take much of a beating?
any input from anyone who has a k-member would be good :P
Old Dec 10, 2003 | 09:07 PM
Xride's Avatar
and what the hell does the stock thing look like???
Old Dec 10, 2003 | 09:08 PM
www.bmrfabrication.com
You can check out the prices there. They are streetable of course and much stronger than the stock ones. Good luck.
Old Dec 10, 2003 | 09:10 PM
Terran2k's Avatar
lol i was wondering the same thing. I assume its made from some other material, rubber or something instead of metal
Old Dec 10, 2003 | 09:16 PM
klbjoc's Avatar
I got mine from ACA for $375.
That was as cheap as I could find it.
