First freeze, and now grinding.
Old Dec 11, 2003 | 08:36 AM
b-stevens's Avatar
So we had our first snow/freeze over yesterday and last night along with some rain earlier in the day. Now today when I drove the car to class this morning I heard grinding when braking, at first it was extremely loud, i pulled over checked to see if it was something caught in the wheel-well, nothing there, drove a few feet sure enough still there. By the time I got home it had quieted down quite a bit and it doesnt even make the noise unless you brake hard anymore. What should I contribute this to? Wouldn't the noise be consistent if it was worn brake pads or frozen calipers/rotors or something of that sort?
Old Dec 11, 2003 | 08:45 AM
b-stevens's Avatar
Ok I turned the car off and let it sit for about 15 to 20 minutes, started it and drove it again and everything was fine?? wtf?? i tried brake on both right and left turns, hard and soft, braking hard while driving straight, reverse, etc and no signs of that noise. What happened??
EDIT: there was part of a leaf stuck between the caliper and brake pad, but it was not on the side touching the rotor, could that have caused it anyways?
Old Dec 11, 2003 | 10:53 AM
95patriotZ's Avatar
It may be worn out pads still, I had the same problem, It was quiet for awhile then It got really bad and loud, and then it got quiet again, Also sometimes it would make the noise when i wasn't braking, and sometimes it would only when I was braking. Changing pads takes like 15 minutes, just do it to be safe
Old Dec 11, 2003 | 02:19 PM
Rotor get flash rust with any kind of moisture. When you first use the brakes, they can sound awful. It takes a few stops for the rust to wear off and then you are back to normal.
karpetcm
Sep 15, 2015 11:07 AM
damnyankee36
Sep 9, 2015 07:06 PM
colts0455
Jun 30, 2015 05:17 PM
1996LT1Z28
Apr 22, 2015 07:56 PM
KASR_Z28
N2O Tech
Dec 30, 2002 02:44 PM
