Trying to make FAQ, what questions?
Old Mar 22, 2003 | 04:26 PM
  #16
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Update:
I am working on it
I need links to all your exhuast audio and/or video clips
Old Mar 22, 2003 | 11:00 PM
  #17
treyZ28's Avatar
yet another update
www.ltonefaq.com is now ours
I have this so far ( not proof read or spellchecked or edited yet)
Performance Modifications and maintenance questions:
Cold Air Intake (CAI):
What it does:
Replaces stock air box allowing for a less restrictive intake that also sucks in colder air.
Typical gains: 5-7hp on a stock vehicle
Which one is best?:
It is generally agreed that all of popular cold air intakes (K&N, Moroso, SLP) produce almost equal gains. The difference is almost negligible.
Substitutes/Options:
Ram Air
Make you own
Links to making your own http://projecttransam.com/projectdis...y&Value=Intake
Headers:
Links:
Installation:
http://members.aol.com/InjuneerZZ/Tech.htm
Headers Survey:
http://www.rit.edu/~jar5968/headers/headers_main.html
What is does:
Replace factory exhaust manifolds with tubular ports to allow easier exhaust flow.
Typical gains: 10-30hp
Shorty headers: 7-10hp
Mid length headers: 15-20hp
Long tube headers: 25-30hp
Which one is best?
It is also generally agreed that long tubes produce more power than shorty or midlength headers. The header chosen will have significant effects on your vehicles ability to pass emissions. Longer tubes also generally create more noise “Best” is relative to your needs.
Catback:
What it does:
Replace factory exhaust after the catalytic converter with a freer flowing muffler and larger intermediate pipe.
Typical gains: 7-10hp
Which one is best?
Performance wise- again almost all exhaust will perform equally as well. SLP’s Loudmouth exhaust may provide a less restrictive exhaust at the expense of sound muffling.
Substitutes/Alternatives:
True dual exhaust
Cut out
Spark Plug:
What it does: Provide a spark to ignite fuel in the cylinders
Typical gains: N/A Your car won’t run without them. No power gains in switching brands
Which one is best?
For Naturally aspirated engines
A platinum spark plug usually lasts the longest but costs more. AC Delco plugs seem to be trouble free but cost the most. Bosch spark plugs work well for some but not for others.
Vehicles with forced induction (turbo, nitrous, supercharger)
A platinum spark plug is a big no no. A copper NGK spark plug seems to be a popular decision.
Spark Plug wires:
What it does: Relay electrical spark from distributor to spark plugs
Which one is best?
Any 8 or 8.5mm spark plug is fine. With headers, an “over the top” (over the valve covers) kit it’s a good idea. It routes the wires over the valve covers to prevent the headers from melting and grounding out on the hot headers.
how does this general formal sound?
Old Mar 23, 2003 | 01:27 PM
  #18
treyZ28's Avatar
hey guys,
i really need links to your video clips, dyno chards, mod lists and for you to fill out this mod "survey"
what Mod
dyno gain (if known)
track gain (if known)
sotp gain (if known)
Cost
Labor (if applicable)
Gas milage increase/decrease
opinion of it (1-10)
notes:
Install guides:
This can help end the "what mod should I do next"
Also links to any install guides would be nice. I really dont have time to search for install guides for every section
ChrisFrez
Jan 25, 2015 08:06 AM
DropZ
Jan 15, 2015 10:40 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
ChrisFrez
Dec 7, 2014 06:01 PM
JasonD
Jul 15, 2002 02:17 PM
