trying to get the dip stick tube out?
Old Nov 2, 2005 | 11:16 AM
crAzy95z28's Avatar
ok i have my block all the way torn down cept my passenger side head and header...
i cant get the damn dipstick tube out. The bolt is undone and it just wont come up?
i blew my enigne and shattered a piston, so i dunno if the crank got messed up causing the dip stick to get stuck or what?
im about to just cut the damn thing off...
any ideas?
Randy
Old Nov 2, 2005 | 11:29 AM
lt11997's Avatar
Re: trying to get the dip stick tube out?
Mine just pulled right out when I did my header install. I did have to sand off the paint to get it back in though.
Old Nov 2, 2005 | 11:32 AM
lt11997's Avatar
Put a screwdriver on the bracket that holds the tube to the block and hit the screwdriver with a hammer.
Old Nov 2, 2005 | 11:55 AM
STEER_INTO_IT's Avatar
I remeber it helped to bend mine a little bit so I could twist and pull and it finally came out with a little work. Just make sure that if you bend it, the bend is in the middle and not down by the press fit on the block. If it gets bent down by the press fit of the block, save yourself the trouble and replace it, its a PITA to get it bent back in that area.
Old Nov 2, 2005 | 11:58 AM
2000GTP's Avatar
I just wiggled it to and fro while pulling up as hard as possible. It came out....eventually.
Old Nov 2, 2005 | 12:41 PM
Coolformula's Avatar
yea, just take the bolt out and wiggle and pull, it should come out.....
Old Nov 2, 2005 | 01:10 PM
crAzy95z28's Avatar
i got it...i hammered it with a flat head near the bottom of the block!!
damn thing was bent inside the block!
Old Nov 2, 2005 | 02:14 PM
CamaroBoy96Z28's Avatar
Gave you a bit of trouble getting it out eh? Wait until it has to go back in...thats the fun part.
football4life
Oct 4, 2015 07:48 AM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
DarksideII
Parts Wanted
Sep 23, 2015 11:14 PM
dolfan324
Jul 17, 2015 10:34 PM
