Trying to figure out if I have TB bypassed or not
Old Apr 5, 2004 | 04:55 PM
JoeliusZ28's Avatar
Red face Trying to figure out if I have TB bypassed or not
I think my car looks like this , but im not 100% sure. Actually I cant find anything besides the hose that runs from the radiator which connects into the tubing that runs along the intake towards the back of the engine. (does that mean its bypassed???)
If anyone can tell from these pics that would be great.
http://images.cardomain.com/member_i...80_30_full.jpg
http://images.cardomain.com/member_i...0_117_full.jpg
http://images.cardomain.com/member_i...0_118_full.jpg
I wish I had better pictures, but cant get any due to the fact the computer the camera connects to isnt working at the time.
If I dont have the bypass... where are these other connectors? Which side is left and right as in which perspective are you supposed to be taking?
I feel like an idiot right now... please rub it in
Old Apr 5, 2004 | 04:57 PM
Red96Lt1's Avatar
Remove the alternator and then take the pictures. Also look at your TB. Do you have a connection missing on both sides of it?
godofdragons's Avatar
look at your tb. if it is bypassed then there would be two connections uncovered. one on each side
Old Apr 5, 2004 | 04:59 PM
heres a really easy to see diagram
Old Apr 5, 2004 | 05:02 PM
JoeliusZ28's Avatar
thanks, ill run out and look at it.
95Z28ConvertCam's Avatar
in the second picture it looks like you have the right hose going to the steam pipe looks like you did it right but hes right take a pic with the altnator braket off and you should have two diffrent nipples un-capped
Old Apr 5, 2004 | 05:10 PM
JoeliusZ28's Avatar
cant take anymore pictures, do to technical difficulties... I know those pics suck, but im trying to work with what I got.
I looked at it again... on the drivers side of the TB under the intake elbow I found a capped connection... as if someone did the mod... however I see no such connection on the other side. The hose from the radiator is running back to a connection on the passenger side next to the intake.
Old Apr 5, 2004 | 05:14 PM
here you have the same car as me check this out I just did mine this mornning
http://shbox.com/1/tb_bypass.jpg
JoeliusZ28's Avatar
Talking
http://www.westol.com/~brettd/corvette/tb.gif
Ok, the thing I was talking about is the return connection... that is capped.
Old Apr 5, 2004 | 05:16 PM
its prolly allready done if the return is capped
Old Apr 5, 2004 | 05:19 PM
JoeliusZ28's Avatar
just checked again... the feed was hiding on me... its capped too
looks like its been done
Thanks for the help/info guys
Old Apr 5, 2004 | 05:48 PM
"White Knight"'s Avatar
yea the feed line will be pointing down on the passanger side of the throttle body. Hard to get to without pulling the TB. Looks like you got one mod done already
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
NewsBot
Sep 14, 2015 02:02 AM
