Trying to Change coolant, this is becoming a real pain
Old Jun 16, 2003 | 01:01 PM
  #16
Mac96's Avatar
4 quarts per gallon
mixed 50/50
2 gallons dex + 2 gallons water = 16 quarts
Old Jun 16, 2003 | 01:13 PM
  #17
SweetZRag's Avatar
Cool
I drained the block the last time I replaced the oil pan gasket. It was easy because I jacked the motor up off of the motor mounts. Try jacking up the left side motor mount only and you should have enough room to get the plug in and out easily
Old Jun 16, 2003 | 02:49 PM
  #18
BigRich's Avatar
use distilled water only for water part of your cooling system
or if you have a reverse osmosis water purifier, just as good
Old Jun 16, 2003 | 05:58 PM
  #19
Getsome17's Avatar
To flush the overflow reservior all you have to do is take out your battery and remove the 1 or 2 bolts holding it down. It should come right out making it easy to clean
captcorvette
Mar 7, 2015 12:37 PM
Sandersen511
Jan 13, 2015 03:49 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
