True duals rattling!!!!!
Old Jan 8, 2004 | 07:17 PM
gsdz28's Avatar
i've had a set of true duals, dumped before the axle for a while, and I just had them extended, Now ther rattle/Vibrate REALLY BAD when I'm slowing down and at a stop. It's really embarassing, it makes my car sound like a pile!!!
I looked up underneath the car and the duals are touching the torque arm....could that be it???? Anybody have any ideas on how to stop it.
It only rattles when it is in gear, when it is in park it sounds fine.
Old Jan 8, 2004 | 07:33 PM
ABA383's Avatar
My guess is that anything touching the exhaust will make it rattle. My experience with exhausts generally speaking is that you need a good 1/2" all around the pipes to avoid any noise...but I don't have true duals, so I'm not certain how the pipes are routed back there...
--Alan
Old Jan 8, 2004 | 07:37 PM
gsdz28's Avatar
they go up and over the axle. i'll get some pics
Old Jan 8, 2004 | 11:50 PM
gsdz28's Avatar
Nevermind, I see the prob, the Duals are setting right up against the Torque arm.....it's not a pretty sound!!!!!
Old Jan 9, 2004 | 02:41 PM
ABA383's Avatar
Do you have good pix of the system from under the car? I'd like to see them...I've always wanted to try true duals, but have never seen them on a 4th gen...I have 1 3/4 shorties to a big Y, gutted cat and a Borla adjustable cat-back (running with no plate)...would change to duals if there was more power to be had...Thanks
--Alan
Old Jan 10, 2004 | 02:01 AM
kmook's Avatar
Advanced Tech Moderator
Was this how the shop fabbed up your exhaust? Seems like they screwed up and need to fix it. Or did something else happen?
Old Jan 10, 2004 | 02:03 AM
kmook's Avatar
--Alan
Pic More Power
Old Jan 10, 2004 | 09:41 AM
gsdz28's Avatar
No, the shop did it, b/c i just came home with the dual, There is also a nut missing on the duals, which is what is causing most of the noise, b.c it has nothing to hold it in place obviously.
but i'm still concerned about the duals sitting right up against the torque arm......i'm taking it back to the shop Monday
Old Jan 10, 2004 | 12:11 PM
ABA383's Avatar
"KMOOK"...
The system looks good....did you gain anything at the track with the set up? ...and can you get it over the axles? I had turn downs on my Chevelle and it rattled all my window trim screws loose!! It does look like it sounds good...
--Alan
Old Jan 10, 2004 | 12:32 PM
kmook's Avatar
"KMOOK"...
--Alan
I never ran before and after with it so i couldnt tell you of specific gaines. I know you can get it over the axle but Its more complicated and more weight too.
Also Video for sound.
G-BODYT56
Jan 14, 2022 11:14 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
autoxr166
Sep 25, 2015 04:21 PM
