true duals
Old Aug 10, 2008 | 10:34 PM
Bails098's Avatar
true duals
i have a 383 stroker with bolt on and cam, 200 shot of nitrous. What size exhaust pipe should i use for true dual exhaust
Old Aug 10, 2008 | 11:25 PM
mr.green's Avatar
what headers are you going to go with??? my setup i drag on many things and i have 2.5 in i think if you went any higher you would have more of a problem with it dragging everywere but thats just my opinion
Old Aug 10, 2008 | 11:29 PM
Bails098's Avatar
i have mac short tube headers in it now.
Old Aug 10, 2008 | 11:35 PM
mr.green's Avatar
ok well it may just how i have mine setup as how bad i drag....i have no more than 4 inches of clearence at the mufflers but if you set it up good you could maybe get 2.75 or 3 inch out of it....http://www.lt1engine.com/tech/how-to...duals-exhaust/
go there that should help you alot
Old Aug 10, 2008 | 11:40 PM
I push 800 flywheel HP through a pair of 3" pipes.
http://members.aol.com/InjuneerZZ/im...os/Exhaust.jpg
Old Aug 11, 2008 | 11:48 AM
SS MPSTR's Avatar
For the sake of ground clearance, and clearance around everything else (depending on how you are routing the pipes), I'd opt for dual 2.5". I'd be more concerned about the intake tract restrictions, which does generate vaccum on efficient H/C combos.
Old Aug 11, 2008 | 12:01 PM
slomarao's Avatar
pick up some LT's. 2.5 or 3 inch would be plenty. It depends if its over the axle or a dump. Give more info please.
If you go to Ls1 tech and search True Duals you will find endless stuff. Like 25 pages of it. Pics, video's, etc. THe whole nine yards.
Old Aug 11, 2008 | 04:12 PM
klrz28's Avatar
3'' with bullets ftw
Old Aug 11, 2008 | 04:20 PM
NightTrain66's Avatar
I have these on my car . . . .
http://www.jegs.com/i/JEGS/555/30662/10002/-1
http://www.jegs.com/i/Dynomax/289/24222/10002/-1
http://www.jegs.com/i/JEGS/555/30643/10002/-1
http://www.jegs.com/i/JEGS/555/30733/10002/-1
I spent about $120 at a muffler shop having a pew pieces bent and welded but it sounds AWESOME and cost less than a good cat back and ORY while making a lot more power. I have about $400 in all of this getting the parts and installation.
My car was NOT lowered and there was still not much ground clearance.
Lloyd
Old Aug 11, 2008 | 04:34 PM
CANTONRACER's Avatar
My setup....
http://www.putfile.com/album/105520
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
