True dual suggestions?
Hi,
I tried doing some searching, but i found nothing. I am planning on buying some kooks 1 3/4 headers without the emissions equipment. I was interested in running a true dual system with an x pipe and turndowns before the rear axle. I was going to weld a magnaflow cat on each side before the x pipe if they will fit. Basically I'm wondering if there is a stainless x pipe system already out there so i would only have to weld the cats in. Could anyone also suggest what pipe diameter i should be using on the enter/exit sections on the x pipe? Also, what are some good true dual systems that i could look at? I figured true duals would be the best way to go sound and performance wise
Thanks,
Jeff
Thanks,
Jeff
Re: True dual suggestions?
http://www.texas-speed.com/shop/item...d=196&catid=56
edit. it says its for a 98 and up but they make them for the lt1
