True dual suggestions?
Old Apr 6, 2006 | 12:02 AM
GnarlyZ28's Avatar
Hi,
I tried doing some searching, but i found nothing. I am planning on buying some kooks 1 3/4 headers without the emissions equipment. I was interested in running a true dual system with an x pipe and turndowns before the rear axle. I was going to weld a magnaflow cat on each side before the x pipe if they will fit. Basically I'm wondering if there is a stainless x pipe system already out there so i would only have to weld the cats in. Could anyone also suggest what pipe diameter i should be using on the enter/exit sections on the x pipe? Also, what are some good true dual systems that i could look at? I figured true duals would be the best way to go sound and performance wise
Thanks,
Jeff
Old Apr 6, 2006 | 10:59 AM
KillWhitey's Avatar
Re: True dual suggestions?
http://www.texas-speed.com/shop/item...d=196&catid=56
edit. it says its for a 98 and up but they make them for the lt1
Javi Fierros
Exhaust System
10
Apr 20, 2017 12:46 PM
Firechicken350
Jun 6, 2015 11:25 PM
QuickSilver02
Apr 7, 2015 11:12 AM
alphaauto
Jan 22, 2015 08:02 PM
