True Dual Install
Old Oct 2, 2005 | 02:21 AM
lasness's Avatar
True Dual Install
Looking to install a set of true duals with billut mufflers on a 93 camaro off a set of PaceSetter long tubes. Can any give me some info on the parts and sizes I should get I wanna atleast do a 3' system. Looking to buy the parts tommorow so I can weld them up so please respond asap.
The info i am looking for it the x pipe types and all the other maderel pipes that I would need to purchase.
Landon
Old Oct 2, 2005 | 09:17 AM
Jameslt1TA's Avatar
Re: True Dual Install
I think the simplest way to go is to just buy collectors, summit brand x-pipe, bullet mufflers and some turndowns. I wouldn't go with 3' though if i was you that is kinda big and will provide you with no ground clearance. I dont have any clearance with 2 extra people in my car.
check sig for true dual pics.
Old Oct 2, 2005 | 12:15 PM
speedmiser's Avatar
The lowest point on my 3" duals are the header flanges (using hooker LTs).
Old Oct 3, 2005 | 01:17 AM
revtime's Avatar
Yep, header collectors (flanges) are the lowest point on my car as well.
I simply installed purple horny header mufflers with turndowns. I had O2 bungs welded into the hornies as my Hooker LTs were ordered without em. Simple true dual setup that is very easy to remove.
X pipe setup would be a little more complicated and I would have a professional weld me up a system if I was going that route.
Ground clearance is a big issue with true duals, I can take 1 passenger thats it. I have no backseat, and I treat the car as a 2 seater.
Although at this particular time it only has 1 seat in it.
Old Oct 3, 2005 | 07:11 AM
teke184's Avatar
the Xpipe will give you better hp gains, the X acts as a scavenger to pull exhaust out.
i think the sound will be better too, compared to non-connected duals like described above.
2.5" duals should be fine for a bolt on car. and you'll get better clearance and a little cheaper.
Old Oct 3, 2005 | 11:24 AM
SS MPSTR's Avatar
2.5" duals is fine for most cars, as long as the bends are smooth (mandrel at tighter turns) and the muffler (if any) is free-flowing.
Old Oct 3, 2005 | 11:30 AM
lasness's Avatar
Can you guys post some pics so I can get an idea of what to use as well as get some ideas.
Landon
Old Oct 3, 2005 | 11:43 AM
teke184's Avatar
here is Texas Speed's rumber X system, happens to be for the LS1 but the idea is the same.
here are a bunch of pics of the true duals that Lanes performance fabbed up. several different routes you can take.
QuickSilver02
Apr 7, 2015 11:12 AM
alphaauto
Jan 22, 2015 08:02 PM
Queens94z28
Nov 20, 2014 06:03 PM
RedLineRev
Jan 23, 2003 03:51 PM
