Vacum Leak?
Old Oct 3, 2005 | 12:57 AM
NipNaZ28's Avatar
Vacum Leak?
well my car was running great for a while but it always had this problem during idle that it would sometimes start to rev up from 800-1500 rpms when idling. I talked to my mechanic and he said it was probably a vacum leak. does anyone know how to check it out. i check along the intake and everything seemed like it was fine, maf, tb, intake were all connected correctly and didnt have a leak. What else could it be, where else could i check. I dont really want to take it in a pay big bucks to get it fixed if i can do it. plus the car still runs great
Old Oct 3, 2005 | 07:26 AM
Re: Vacum Leak?
A hand held tester like a Mityvac is a good tool to help trace any vacuum leaks in hoses or apparatus.
Your IAC could also be dirty, causing erratic idle.
Old Oct 3, 2005 | 11:49 AM
NipNaZ28's Avatar
Re: Vacum Leak?
i did the throttle body bypass do you think that could be it? but if i rememebr correctly i think it even did it before then
Jeff1904
Jun 5, 2016 05:00 PM
magman
Apr 15, 2016 03:08 AM
blac94Z
Nov 4, 2015 01:59 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
