True Dual Exhaust setup? Options and whats needed?
Old Jun 6, 2005 | 09:12 PM
zbomb5610's Avatar
What are my options for setting up a true dual exhaust setup on a 96 camaro LT1?
The car is lowered, so i should probably run some long tube headers, should I go with an x pipe, or straight duals? What problems with clearance will i have?
I just need some options on what setups i can run, and exactly which parts and part numbers I need.
Any help is appreciated.
Im looking at 3" dual exhaust setups since I will be having a 383 motor with Lloyd ported Trickflow heads, lt4 intake manifold ported, lloyd cam, and some other things so i figure 3" is the best way to go since i have the power for it.
Old Jun 7, 2005 | 03:53 AM
zbomb5610's Avatar
Re: True Dual Exhaust setup? Options and whats needed?
3" exhaust setup
is that exhaust setup with some pacesetter LT's a good way to go? Is there anything I should worry about with that setup?
is there a better option out there that won't cost over $700.
I would probably get some bullet mufflers to go along with that.
How mean would that sound with a 383, lloyd ported trickflow heads and ported lt4 intake with custom cam by lloyd?
I don't want it to be as loud as straight exhaust with no cats or mufflers but i want it to be louder and sound meaner than my american thunder flowmaster setup.
Old Jun 7, 2005 | 06:16 AM
Kurt Crosbie's Avatar
Go with really any brand of longtube header. then get a dr. gas x-pipe to bolt up to it. those sound real nice along with the longtubes. Then attach the dynomax bullet race mufflers to the x-pipe. Nothing, IMO, sounds better and makes more power.
I picked up my setup (custom x-pipe and dynomax bullet race mufflers w/dumps) fully assembled for $110. Just look around.
Old Jun 7, 2005 | 01:29 PM
zbomb5610's Avatar
When you dump the exhaust so it faces down at an angle, does that cause the exhaust to have the same effect as when you would normally drive by a divider on the road and it resonates off the wall?
is the purpose of the downward dumps to make it louder?
Old Jun 7, 2005 | 01:44 PM
I am actually not sure what the purpose of the dumps is. I think directs exhaust fumes away from the cockpit.
Old Jun 7, 2005 | 02:28 PM
zbomb5610's Avatar
last question, would i have to worry about clearance with 3" duals if my car is lowered with the eibach sportline springs? i think that is a 2" drop
Old Jun 7, 2005 | 03:06 PM
Yes, you will scrub every now and then.
alphaauto
Jan 22, 2015 08:02 PM
4586
Dec 31, 2014 02:21 PM
Queens94z28
Nov 20, 2014 06:03 PM
RedLineRev
Jan 23, 2003 03:51 PM
