trouble code help please!
Old Jan 3, 2008 | 11:39 AM
crazypurgatory's Avatar
Question trouble code help please!
Well my 1997 Z28 just set a code today I have p0420 witch comes back to "Catalyst System Efficiency Below Threshold (Bank 1)"
I have also been having a code p0410 that comes back to my smog pump witch seams to be replaced.
Now I need some help here on the p0420 code bank one is the drivers side?
If it is then is it the O2 sensor or is there a down stream O2 sensor on the drivers side like there is on the passenger side.
Or is it the converter on the drivers side?
Thanks,
Old Jan 3, 2008 | 12:06 PM
P0420 sets when the after-cat O2 sensor on the driver's side indicates that the catalytic converter is not performing correctly (low oxygen storage). That can be caused by several problems:
-dead cat
-faulty O2 sensor
-faulty wiring to the sensor
Swap the two after-cat O2 sensors side-to-side - that will tell you which one is the problem. If the problem/code moves with the sensor (P0430), its a faulty sensor. If the problem stays on the driver's side (P0420) its most likely the cat, but you should check the wiring as well.
Old Jan 3, 2008 | 12:11 PM
I will have to do that tomarrow it's to dam cold for me 54F out in west palm beach florida.
Old Jan 3, 2008 | 05:17 PM
No sympathy on the temperature... It was 13*F driving to work this morning, in NJ, with a 20mph wind.
Old Jan 3, 2008 | 06:02 PM
JBird33's Avatar
Predicted wind gusts of 75-85 MPH here with snow accumulation of up to 2-4 feet...
Old Jan 3, 2008 | 06:12 PM
93v8clone's Avatar
-5 this mornin with a foot of snow on ground
The Engineer's Avatar
I heard it was "so cold" in West Palm Beach this week a few people were actually seen wearing long pants! Burrrrrr!
WD
Old Jan 3, 2008 | 07:12 PM
Talking
WD
Yup you got that right.
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
