trouble code ?
trouble code ?
does anyone know what trouble code 18 is?? it is a 94 Z OBDI car.. runs rich and fouls plugs.. has a pretty bad "hobble" while driving also. brand new MSD opti, coil, and wires?? everything is done right, as ive done it a few times now. Stumped!!
well, after a little looking, i found troublecodes.net and it said 18 was "injector driver circuit voltage to pcm was wrong for 4 seconds". im feeling kinda dumb but what do i look at? thanks
You can find a link to a list of f-body specific trouble codes in my sig.
18 means you need to check your injector wiring and/or injectors, because the PCM detected a fault. Injector resistance should be ~12 ohms. Each injector gets 12v on the pink wire. The other wire gets a ground when the PCM fires it. You can check the individual wiring with a noid light.
i understand that.. but you said it could be the injectors themselves... if it is the injectors themselves, would cleaner work at all? would it be worth the 6 or 7 dollars to buy a bottle
The electrical failure in an injector would be a failure of the coil that moves the injector open. That has nothing to do with cleaning the injectors. The PCM can not use DTC 18 to indicate if an injector is plugged or stuck open. It can only look at the voltage on the circuit when the injector is energized or grounded, and use that to determine if there is a fault in the circuit.
armedtrigger
Feb 24, 2015 08:30 PM
