TRickflow heads
Old Mar 9, 2005 | 12:41 PM
vonmoldy's Avatar
TRickflow heads
I was wondering if anyone has the new TRickflow heads installed and How they like them? Anyone know what gains i would see on my car? Would it be worth it at this point? See signature.
Old Mar 9, 2005 | 12:42 PM
'94 Bad A Z28's Avatar
Re: TRickflow heads
Heads on a LT1 with a stock cam is almost pointless.
Old Mar 9, 2005 | 12:51 PM
Camaro97USAF's Avatar
Re: TRickflow heads
I have em... I like em. They need to be milled a bit to keep cr though. I would hold off on getting heads until you get a cam put in with them.
Old Mar 9, 2005 | 12:52 PM
kamba93lt1's Avatar
Re: TRickflow heads
Depending on how much the Trick Flows are you would be better off get a set of ported stockers and a cam.
Ken
Old Mar 9, 2005 | 06:53 PM
Rpm280's Avatar
Re: TRickflow heads
I would probably wait to get a cam also , if a cam was planned in the future.
But I would not say pointless. Look at Ls1's . Better head flow will increase power even with a stock cam.
Old Mar 10, 2005 | 12:12 AM
vonmoldy's Avatar
Re: TRickflow heads
I would think they would add more power to stock motor for the same reason intake and exahaust do...now with a bigger cam the heads would add even more because there wouldnt be the stock head restriction. Just seems logical but is it correct??
Old Mar 10, 2005 | 01:24 AM
SStrokerAce's Avatar
Re: TRickflow heads
They are a great head for porting and strokers.... I've seen some 300cfm examples in the shop and even after you get the chambers done to work with the valves you can't get them much lower than 56-57cc even after angle milling.
For a stock bottom end motor that's not going to have a blower on it, stick with LT1 castings that are ported.
Bret
Old Mar 10, 2005 | 01:30 AM
v7guy's Avatar
Re: TRickflow heads
I believe those are the heads they state right on the site that they will not perform well on a stock LT1, they're meant for FI applications
Old Mar 10, 2005 | 12:10 PM
vonmoldy's Avatar
Re: TRickflow heads
But bringing back to the question I originally asked or should I say I was more interested in hearing answers about...Does anyone have them on their car? How do they perform?? With a cam and the heads what gains are realized?
Old Mar 10, 2005 | 01:01 PM
Re: TRickflow heads
As I said, I do... dyno sheets on my webpage in the sig. Only time I took it to the track I got a 13.3, because I spun a bearing and my car shut off halfway through. Working on getting that fixed though...
Old Mar 10, 2005 | 01:16 PM
tireburnin's Avatar
Re: TRickflow heads
97USAF,
Did you just spin the bearing? That's terrible to hear, but look at it as an opportunity to improve it. Raise the compression a lil (11-11.5) with some aftermarket pistons, some good rods and new bearings and it will be golden.
Your car was on its way to making some serious power with the stock bottom end. Hope you get it back together soon, I've been there and done that and it is not fun having to redo all your hard work.
Good luck
Old Mar 10, 2005 | 02:17 PM
CANTONRACER's Avatar
Re: TRickflow heads
rpm280....You do know the LS1 a chunk larger than an LT1 cam right.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
