Trickflow guidplate question
Old Mar 9, 2009 | 05:54 PM
Dave1980's Avatar
After putting my pushrods in the motor today, I noticed that i have very little clearance from pushrod to guideplate on bottom portion.
How much clearance do you normally need?
Also does anybody know if they are hardened all the way through?
And last question, what is every body using to grind them with? (dremel?)
Old Mar 9, 2009 | 06:27 PM
lt1-xjs's Avatar
When I installed mine with the 1.7's they almost if not touched. This was at the bottom of the 'U'. I used a die grinder with a 3" wheel to grind the notch deeper, 1/16" to 1/8". Be careful not to touch the sides.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
Roadie
Feb 16, 2015 10:34 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
