Trickflow 58mm throttle body?
Old Apr 14, 2009 | 11:05 AM
96LT1TX's Avatar
I am looking at 58mm TB's and trying to figure out which TB I will make the most power with and have the least problems with.
Anyone have any advice?
Old Apr 14, 2009 | 11:11 AM
wrd1972's Avatar
I have the Summit racing 58mm TBwhich is actually made by BBK. No problems with it. All the 58mm TB's will make the same power.
Old Apr 14, 2009 | 01:22 PM
96LT1TX's Avatar
Ya, I agree with that mostly. I was leaning more towards the least problems phrase there. BBKs are seemingly cheaper than the AS&Ms and the Holleys. Hope this isn't for a reason... I am ordering the BBK right now.
Old Apr 14, 2009 | 07:15 PM
wrd1972's Avatar
It will be fine.
Old Apr 14, 2009 | 08:07 PM
96capricemgr's Avatar
Summit owns Trickflow so if Summit is BBK it is highly likely Triclflow is too.
All the aftermarket TB need the IAC bleed drilled.
AS&M is billet artwork but is hard to make the IAC circuit work right with. Holley has sticking issues.
Only issue specific to BBK is older ones whistle some I think they addressed it though.
Old Apr 14, 2009 | 08:23 PM
wrd1972's Avatar
Yeah good point. I had to drill the hole in the IAC passage but the TPS sensor needed NO modding at all. I had to adjust the blades position and that was it. No blade sticking at all.
FTR, I read that the Summit was a BBK. I dont want to stand on it as being fact. It could be a trickflow afterall.
Old Apr 14, 2009 | 09:46 PM
96LT1TX's Avatar
I shipped the BBK. So I will read up on the drilling in the IAT. I have seen a lot of people post about this, but some people say they dont have to as well. I will leave it the way it is if at all possible.
Old Apr 15, 2009 | 05:15 AM
wrd1972's Avatar
It depends on what the IAC counts are. You will need a data logger to measure this. Mine were well above 100 which is too high. The drill mod brought them down to about 50 or so.
Old Apr 15, 2009 | 07:43 AM
The TPS mod was for people who failed to understand the IAC circuit and were opening the blades to get the IAC count down, then they would slot the tps to get that back to zero with the blades cracked open.
Old Apr 16, 2009 | 06:59 PM
96LT1TX's Avatar
So caprice, I have yet to do the research, but you are saying you can add a resistor or do something electrically to do the same thing?
Old Apr 16, 2009 | 11:49 PM
87bandit's Avatar
I've had great luck with the professional products one
I believe the summit one is a pp because my friend has a summit tb and it is identical to mine
also the pp one is $200~
Old Apr 16, 2009 | 11:56 PM
No, he's not suggesting a resistor or some electrical mod. He's just explaining how some people approach the issue of getting the IAC counts, the RPM and the TPS voltage dialed in. What works is not necessarily the same for everyone.
And isn't PP a Chinese copy of the BBK?
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
