Trick to loosen O2 sensor?
Old Mar 13, 2008 | 08:15 PM
  #31
wrd1972's Avatar
Heat it with a torch and be done with it.
Old Mar 13, 2008 | 08:25 PM
  #32
LSWHO's Avatar
Well damn it all. I am just going to buy headers and leave that bastard on there.
Old Mar 13, 2008 | 09:52 PM
  #33
wulfen33's Avatar
Perfect! Always use a r/r job to justify a mod to the woman if you can.
Old Mar 13, 2008 | 09:59 PM
  #34
SS RRR's Avatar
It's possible to damage the threads if the sensor is practically welded into the bung. If the threads do get damaged you can use a spark plug hole thread chaser for a repair.
Old Mar 13, 2008 | 11:31 PM
  #35
buzz12586's Avatar
Use a torch on it. Makes it a simple job.
Old Mar 13, 2008 | 11:52 PM
  #36
fireman's Avatar
Thats the best idea yet!
I know a local guy that has some Pacesetters he is not using
Old Mar 14, 2008 | 12:08 AM
  #37
LSWHO's Avatar
Strange, my brother has some pacesetters in town he is not using...
Too bad I just spent 2k on a tranny/converter.
Old Mar 14, 2008 | 02:20 AM
  #38
Dave1980's Avatar
Thats good info on the spark chaser. When I pulled off my exhaust this last time, I had cut it in pieces. (I replaced it front to back so no big deal) I removed the o2 sensor in a vice with a map gas torch. (burns hotter than butane)
Even then It still messed the threads up on the way out. It did not matter at that point since the exhaust got junked. I guess if the sensor sits in there long enough it can fuse with the exhaust.The reason I kept mine, was for the new headers. ( I heard the coating can foul up new o2's)
Exhaust rusts over time, and those threads will eventually just rust up completely.
I saw in the rebuilding LT1 book, that they used parafin wax on stubborn bolts. (heat up the part then cover with wax) It is supposed to melt into the threads. I wonder if this is a good thing to try?
Old Mar 14, 2008 | 06:51 AM
  #39
Wild Willy's Avatar
If you don't want to try and save the sensor, cut the pigtail off, and use a 6-point box wrench- Like everyone has said, heat is your friend. I have had good luck just letting the engine run for ten minutes, but the next step up would be MAPP gas- similar to propane, but hotter- heat the pipe around the joint, not the sensor
Recommend using AC-Delco for the replacement- I think their tolerances are a little tighter-
KYWes
Jun 14, 2022 06:52 AM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
pimpen1024
Jul 8, 2015 09:08 PM
