Trick Flow Throttle body- Anybody have one?
Old Feb 20, 2010 | 07:55 PM
LT1inaMGB's Avatar
Just saw a listing for a 58 mm LT1 Trick Flow throttle body in the new Summit catalog. Anybody run one yet? The say it has a screw adjustable idle setting. Couldn't find any info on the internet.
Jim
Old Feb 20, 2010 | 10:42 PM
All LT1 throttle bodies have an idle adjustment screw. But you don't use it, you let the PCM control the idle speed, using the idle air control (IAC) motor. The exception would be using the idle adjustment screw to get the IAC "counts" into the correct range, so the PCM is able to control the idle over a wide range of conditions.
Old Feb 21, 2010 | 07:22 PM
HardcoreRM125's Avatar
Ditto - Injuneer has helped me with 1000's of suggestions over the years and I have yet to find him wrong. He knows his stuff. Only use the screw to set the IAC counts into the correct range so the IAC motor can control the idle over the largest range of variables in temp, humidity, etc.
Rosko018
Jun 26, 2015 01:52 PM
BinkZ28
Apr 20, 2015 09:10 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
