Trick Flow Intake Elbow
Old Sep 4, 2005 | 11:54 AM
  #16
speedmiser's Avatar
Re: Trick Flow Intake Elbow
Originally Posted by tireburnin
A hard intake elbow is EXTERMELY nice for nitrous applications. If you have a back fire, you won't end up buying two elbows. They are also nice for mounting nozzles in (very secure mounting).
I was thinking the same thing, when reading the thread.
Old Sep 22, 2005 | 09:10 PM
  #17
mthegodfather's Avatar
How did everyone mount there Optispark vent tube with the Trick Flow elbow?
Old Sep 22, 2005 | 09:23 PM
  #18
crazypurgatory's Avatar
Lightbulb Re: Trick Flow Intake Elbow
Hay look at summit.
http://store.summitracing.com/defaul...s=P%5FRank%7C0
Chris G.
Old Sep 22, 2005 | 09:26 PM
  #19
That is a good deal.
Old Sep 22, 2005 | 09:33 PM
  #20
80TA's Avatar
I got one and had some problems with the cheap crap couplers.Anyone know the correct size in silicone that would work. I like silicone from my turbo cars much better than cheap crap that comes with it.
And to vent opti you drill a hole in the trick flo. Its already got an iat hole in it.
Old Sep 22, 2005 | 09:49 PM
  #21
Does anyone know what size hole and where to get a grommet for it?
Old Sep 23, 2005 | 01:53 PM
  #22
Would it be safe to drive the vehicle any without this vacumn line hooked up?
Old Sep 23, 2005 | 02:08 PM
  #23
Jazsun's Avatar
My car gained 30RWHP from this, DYNO proven. And we got an extra 5HP from the sticker I put on my bumper.
Old Sep 23, 2005 | 02:10 PM
  #24
What was the point of that?
Old Sep 23, 2005 | 03:36 PM
  #25
tireburnin's Avatar
It won't "hurt" your car to have the opti vacume off as it really serves to keep it dry and such. I wouldn't recomend it though. You can simply attach the vacume line into the rubber couplers. Drill/cut a hole and use some sort of vacume line that will allow for you to hook up the line. Not very complicated...just fit it into the intake tract somewhere. You could even take your vacume from before the MAF in those rubber elbows and gromets.
Old Sep 23, 2005 | 03:40 PM
  #26
So it is fine to put it before the MAF? There isnt any room on the couplers after the MAF but I have something I can hook up to before it.
Old Sep 23, 2005 | 04:14 PM
  #27
tireburnin's Avatar
You just need some sort of vacume.
Vacume is vacume as I understand it.
Old Sep 23, 2005 | 04:18 PM
  #28
95 TA's Avatar
The kit comes with the grommit and instructions on what size hole to drill and location. Pretty easy stuff. It does add a nice touch under the hood even if it doesn't add performance.
Old Sep 23, 2005 | 04:19 PM
  #29
I bought it from someone on here so I dont have the grommet or instructions.
Old Sep 23, 2005 | 06:23 PM
  #30
Well I would call Trick Flow up and ask if you can get one from them.
I'm sure they would just give it to you.
If not it can't cost much.
Chris G.
