transmission shift kit questions
Old Sep 11, 2003 | 10:03 PM
97firev6's Avatar
My car has a shift kit installed and it shifts extremely hard into second gear. Does anyone know of anywhere i could get a cheap stock valve body for the trans?
Old Sep 12, 2003 | 06:24 PM
Pro Built Automatics's Avatar
If this is the Trans-Go Shift kit, then most likely whoever installed it put in 2 or 3 washers in the 2nd gear accumulator. You can drop the pan and remove them, it is fairly easy to do, or you can have the person who installed the kit do this. If it is another name valve body kit, then most likely the 2nd gear feed hole is to large, and/or the 2nd gear accumulator is blocked, this is harder to fix.
Old Sep 12, 2003 | 06:49 PM
windnsea00's Avatar
my tranny shop said my trans go wasnt adjustable? i really want it to shift firmer, i feel like i got a bit ripped off...
Old Sep 15, 2003 | 02:13 PM
The Trans-Go is completely adjustable. You might try someone else that is familiar with this kit.
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
RedLineRev
Jan 23, 2003 03:51 PM
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 10:44 PM
