Trans wont shift into 3 or 4, sometimes it does. HELP
Someone please help.
I have a 94 camaro with a 4L60E and all of a sudden my car wont go into 3rd or 4th under part throttle. When I am at a stop light and take off normal, it shifts hard into 2nd and when it comes time to go into 3rd, it dont, it just wants to rev. Now if I come to a complete stop and give it over 50% throttle it will *usually* go in to 3 and 4 and the converter will lock just like normal. It will even chirp the tires on the 2-3 shift. And then everything feels fine from there unless i come to almost a complete stop and then it all starts again. I have Transgo shift kit and a 3600 Vigilante converter. I changed the 1-2 and 2-3 solenoid from another 4L60E, but the problem is still there. The fluid is full but appears dark only after 1000 miles. I dont think it is the clutch packs because why would it still hold third and forth sometimes even under WOT when it decides to go into 3rd? I even tried another computer with no luck. Is there anything I can to fix it? Thanks for your help.
Jason
Jason
Oh and also, when the car and trans warm up it seems to want to go in to third more often. If i ride out second gear with a pretty go foot on the throttle and shift it in to third after 27 mph it goes into all above gears. but if i go easy on the gas and shift into 3 it wont go it will just rev. anybody?
Rich_z28
Aug 29, 2002 10:44 PM
