trans grinds when shifting.... What is it?
Old May 9, 2005 | 09:23 PM
raroz28's Avatar
When I go to take off it grinds. If I give it more gas while letting the clutch out, it grinds worse. I have to let the clutch out really slow and leave it at like 1500-200 RPM. If I don't let out slow, it will grind. I am thinking t/o bearing. What else could it be? Clutch grabs good when I take off. It's like I have to pop the clutch. It's not chattering, it's a grind. Coming from the trans... I'm stumped.
Old May 9, 2005 | 09:40 PM
Robs97Z28's Avatar
Re: trans grinds when shifting.... What is it?
your friction disc may have come apart, causing metal to metal contact.
Old May 11, 2005 | 12:37 AM
raroz28's Avatar
that doesn't explain how it grabs so good once it's engaged though... I'm thinking I need a new clutch kit, but I can't figure out what would cause this. I've never seen anything like this before. Anyone else have a suggestion?
Fastbird93
May 22, 2015 08:28 PM
blkWidow
Apr 21, 2015 01:56 PM
willie-d-nice
Feb 13, 2015 06:40 AM
vb95z28conv
Jan 27, 2015 08:32 AM
