Trans Dipstick Tube
Old Jul 2, 2003 | 06:25 PM
94_Z28_guy's Avatar
Trans Dipstick Tube
Do I need to add some sealer around the tube seal or something? I am sure it is seated, but it leaks as soon as I put fluid in.
Old Jul 2, 2003 | 08:24 PM
94_Z28_guy's Avatar
I just pulled the tube off, and the rubber seal is chipped in one spot where it sets in the hole.
Can anyone recommend rtv sealer, or try to replace the rubber seal?
Old Jul 2, 2003 | 08:39 PM
z2894convertible's Avatar
I would replace the rubber seal. If not......try some high temp gasket sealer. I fixed a leak on my radiator with it.
Old Jul 2, 2003 | 09:43 PM
94_Z28_guy's Avatar
Can anyone tell me if the rubber seal goes in the hole first, or on the trans tube first?
When I pulled out the trans tube, the seal is on the tube, and won't budge when trying to take it off. So I was trying to push the seal back in while on the tube. Don't think that's right .......
Old Jul 3, 2003 | 12:23 AM
Chris 94Z A4's Avatar
Mine kept popping off under hard acceleration. I replaced it with one from a '95 as it has a locking lever.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
Mar 13, 2016 03:39 PM
jmadoll
May 27, 2015 07:13 PM
jmadoll
Mar 3, 2015 10:16 AM
