Trans Am AND Blazer problems!!!
Old Dec 30, 2004 | 12:41 AM
  #16
StickMaster's Avatar
Re: Trans Am AND Blazer problems!!!
Looks like you need new 02's or at the least a new bank 2 02, id replace both
PO131 H025 LOW B1S1
PO151 HO25 LOW B2S1
my guess would be bank1 sensor1, bank2 sensor1, i believe sensor 1 is the the before the cat
im just guessing those are 02 codes the only thing that makes sense to me
Old Dec 30, 2004 | 12:55 AM
  #17
jbird's Avatar
Your small leak in the evap. system is nothing to worry about, Unless it's the line to your intake (not sure if that's where it goes on blazers). Most of them have a charcoal canister to vent fumes from the gas tank. The hoses get brittle and crack a lot. Voila!! Small leak. Gone through that with mom's dakota like four times now. Also, if it has less than 100k miles I believe it is the dealership has to fix emissions stuff gone bad, that is, if my memory serves me correctly. So, if all is as I think it is, they should fix your evap leak for you under warranty.
Hopes this helps explain the evap. code a little.
Old Dec 30, 2004 | 02:14 AM
  #18
MentalCaseOne's Avatar
You guys gunna hate me BUT if you give it gas and the car falls on its face doesnt sound like a vacum leak that I ever known of. When you open the Trottle "then it now becomes the huge Vacum leak right there" unless there is enough gas to mix with the incoming air and make it into a burnable mix....else it will fall on its face and that my friends makes me think.... About the Oxygen sensors... that makes lotsa sense... If the sensors keep the puter from adding extra fuel for the additional air then the car "should fall on its face too"
Now I am not expert on this crapola, I am just opening my big mouth so dont take me out and shoot me..... Ok?
Marvin
Old Dec 30, 2004 | 02:15 AM
  #19
Eric85's Avatar
hey i have a 96 Jimmy which is the same thing man and mine acted that way and it ended up being the MAF sensor was bad.
Old Dec 30, 2004 | 02:51 AM
  #20
Dave89IROC's Avatar
Marvin
the reason I said to check fuel pressure
Old Dec 30, 2004 | 10:15 AM
  #21
thefox1's Avatar
hummm, I wonder if I can try another MAF. Does anyone know if the one from my 94 Trans Am would be compatible?
Old Jan 3, 2005 | 01:40 PM
  #22
Why dont you check out the 02s?
Old Jan 4, 2005 | 10:26 AM
  #23
thefox1's Avatar
Haven't had time to have a look at them yet. But the temperature has gotten a lot milder lately and the Blazer has been doing a lot better, which leads me to believe that it's an air gas mixture problem.
Old Jan 8, 2005 | 01:08 PM
  #24
thefox1's Avatar
I finaly got the Trans Am started!! But I'd really like to know why Te only thing that I did was disconnect the battery for about a day and then she started without a hitch!
Any ideas what caused this??
Old Apr 1, 2005 | 07:55 PM
  #25
thefox1's Avatar
About the Blazer, I was thinking, it sounds so much like fuel starvation. When did you last replaced the fuel filter?
If you fix it, post it back so everyone knows how you did it.
Marvin
I found the cause of te problem, fuel pump. Changed it and the car runs great!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
Sarahrope64
Nov 27, 2014 11:17 AM
siguy
Nov 27, 2014 10:07 AM
