Tranny Shake on Highway @ Low RPM?
Old Aug 4, 2007 | 01:45 PM
Pandamonkey's Avatar
What the hell is this?
When I'm on the highway doing 65 or so in 6th and I give it some throttle to gain a bit more speed to pass or whatever - the whole tranny shakes and bounces. So I put it into 5th to raise the rpm - then it's almost gone but still a bit there.
Seems like the car is hesitating at low rpm also - like there is a bit of a cough and a shake when shifting between gears.
I thought it could be a motor or tranny mount.
Any ideas?
Old Aug 4, 2007 | 01:53 PM
Sounds like you have a miss. A miss is always more obvious in higher gears.
Old Aug 4, 2007 | 02:05 PM
Steve0's Avatar
How are your wires? Replaced them recently? Check for a burnt/damaged plug wire.
Old Aug 4, 2007 | 03:35 PM
Ahh........that would be so much better than having to replace a mount.
I am actually still running the stock wires - it may be time to replace.
What wires are best? MSD?
Old Aug 4, 2007 | 04:51 PM
Lol, replacing a transmission mount would be cake vs. replacing plug wires.
Old Aug 4, 2007 | 05:25 PM
droptop z's Avatar
I got the same problem right now, just checked my plug wires and I found the #3 cylinder spark plug boot all cracked and brittle from my headers. Hopefully after I swap it out the miss will be gone.
Old Aug 4, 2007 | 05:55 PM
HA! You're right shoebox! I don't know why I thought that changing the wire could possibly be easier than a mount..........
Hell, the plugs alone took me 5 hours - so I can imagine the wires will take all freakin day!
I think I'll change the opti out while I'm at it, for the MSD model.
timmy39120
May 8, 2015 11:41 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
