tranny lines... got an idea
Old Jun 29, 2003 | 04:56 PM
1994TransAm's Avatar
hey guys,
i bought a new tranny and stall for my 94 TA. i cut the old lines to get the tranny out in a hurray, plus i knew i would have stripped the lines connections anyways......
on the LS1 M30 (4l60e) the lines use a snap in fitting on the end (tranny)....... LT1dave told me about this.... anyone else used this or seen these lines before?
Old Jun 29, 2003 | 04:59 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
i took the lines out no problem... take off the cat heat shield (or you'll cut your hand/wrist up like a mother) and use a shorty wrench...
Old Jun 29, 2003 | 05:23 PM
12SCNDZ's Avatar
The holes in your case that the fittings screw into are the same size. You can just screw your originals into the new transmission case. If you choose to use the fittings with o-rings and retaining clips, you'll have to replace your cooler lines.
Frank
Old Jun 29, 2003 | 05:29 PM
12SCNDZ's Avatar
BTW, you know the lockup strategy is different on '95-up 4L60E's, right? They use a Pulse Width Modulated PWM solenoid in the valvebody to control lockup feel. If you install a '95-later trans. in your '94, you'll have lockup problems, and a check engine light. Of course GM tried to make this "idiot proof". The case electrical connectors are different, also.
Frank
Old Jun 29, 2003 | 10:21 PM
i know about the missing silinoid in 94's and dave already took care of it.
i know i have to replace the lines... just wondering if anyone has done this.... thanx for the replies.......
dylan1303
Aug 12, 2015 02:00 AM
FieroLT1
Jun 26, 2015 08:43 PM
Flint78
Jun 21, 2015 01:28 PM
dylan1303
May 22, 2015 12:24 PM
Magenta_Hearts
Mar 30, 2015 09:42 PM
