Heads and Cam or Spray?
Old Jun 29, 2003 | 07:59 PM
silverz28's Avatar
Question Heads and Cam or Spray?
I don't know what to do. I was going to get an NOS kit and then I chicken'd out. I feel somehow it would be cheating to get the NOS kit. Now I'm thinking of some heads and a new cam. That way, the power would always be there. I have stock heads and a HOT Cam installed right now. I'm trying to get into the really low 12's or high 11's. I'm at 12.46 right now. I was thinking of some heads around $1700 and the CC306. If I do, can I still use my heavy duty GM timing set? And, do I need new push rods? I would be doing all the work.
Old Jun 29, 2003 | 08:04 PM
whitehooptie's Avatar
I would go H/C. No excuces of Bottle pressure too low, or no juice, ect. I like the "all motor" route though. You can reuse the chain if you want unless it has a lot of miles on it. You should not need to get new pushrods, but if you do, get chromoly. Better safe than sorry. I would spend a little more money on the heads and go with some CNC AFR's. And look into the extreme energy I think cam grinds. The group with the 503 line. The 306 is a good cam, but I have heard a lot of people putting down good numbers with that 503 cam. Then later, spray it.
Old Jun 29, 2003 | 08:12 PM
Robert95z's Avatar
If you sell your LT4 hot cam, let me know!
Old Jun 29, 2003 | 08:38 PM
FastZinTennessee's Avatar
Put in my vote for heads and cam. Although if I was you I'd probably keep the HOTcam for now and through some heads on there along with a good dyno tune.
John
Old Jun 29, 2003 | 08:43 PM
CamZ2811's Avatar
do it!
Do the 306 w/ ported heads and the spray!
Old Jun 29, 2003 | 08:46 PM
silverz28's Avatar
Thanks. I don't know if I want to keep the HOT cam because I don't think I could go high 11's with it. Plus, if I have to do all that head work, why not a bigger cam with some serious power. Allthough, the HOT Cam is reliable, I don't drive it much anymore. twice a week mabe. I do like the AFR idea though. I have heard good things about AFR.
Old Jun 29, 2003 | 08:57 PM
Well I say keep the HOTcam cause I'm a lazy bastard, and I don't like swapping more things than I have to. But good luck on whatever you decide!
John
Old Jun 29, 2003 | 09:00 PM
Antz97ZNJ's Avatar
If you want to go w/ a more agressive cam go w/ the 306, you should have done that in the 1st place...i say u keep the LT4 get those heads, or port yours and get some spray...your cars already fast....
Old Jun 29, 2003 | 10:21 PM
silverz28's Avatar
Maybe I will keep the HOT cam. Thanks for all the replys.
StansZ28
Feb 19, 2015 07:39 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
