Tranny cooler hoses question
Old Jul 26, 2003 | 10:03 PM
$hawn's Avatar
You know how the top tranny line has a rubber hose connected to a metal line, I think it's the return line, anyways I have my top tranny cooler hose connected to that line, where the original hose was, and have the bottom outlet hose connected w/a fitting to that original hose. So does it matter how there hook up, or should I switch them? The fluid it under pressure anyways isnt it, and will flow either way?
Old Jul 26, 2003 | 10:38 PM
ChickenScreamer94's Avatar
it doenst really matter. Just pull the rubber factory hose off the metal line, choose a line on the cooler, and hook it up to the factory hardline. Then let the other line from the cooler go the factory rubber line. YEs, since it is under pressure, it doesnt really matter.
Old Jul 26, 2003 | 10:41 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
you want the cooler to be on the tranny -> radiator line...
tranny, to cooler, to radiator, to return line...
Old Jul 26, 2003 | 11:22 PM
$hawn's Avatar
I'v had it done for about a year now, but I was just curious if it mattered much which hose went to which ever line. Thanks
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
RedLineRev
Jan 23, 2003 03:51 PM
Javier97Z28
Sep 8, 2002 07:23 AM
chesee48
Aug 22, 2002 08:28 AM
96z
Aug 2, 2002 09:00 PM
