Track times in here 383
Old May 22, 2009 | 11:31 PM
bombebomb's Avatar
Worst run of the night was
60 -2.276
330 - 6.548
1/8 - 9.818MPH - 79.72
1000 - 12.373
1/4 - 14.447
MPH - 109
Runs like that is what I call spin half track then let off and get back in it
Best run
60 - 1.834
330 - 5.151
1/8 - 7.891
MPH - 89.52
1000 - 10.243
1/4 - 12.214
MPH - 114.58
Quickest mph and time
115.00 mph
12.214 ET
How are my times? For a typical stock headed 383 or similar set up.
383
12:1
forged internals
stock unported heads
231/239 550/585~ cam
TD's for exhaust
headers
LCA's
Nitto 555r
Electric w pump
pro mag rockers 1.6
!spare
!jack
!floor mat
!urine
!AC
Old May 23, 2009 | 12:02 AM
lt1srule's Avatar
383 with stock heads NEVER..I run a set of le 2 heads with the 306 cam stock bottem 6sp 11.8 at 121 ..The stock heads are killing you..
Old May 23, 2009 | 12:36 AM
bombebomb's Avatar
I know, heads are in the plans. I also need a 3500 stall, 300 shot of nitrous etc etc.
Old May 23, 2009 | 06:04 PM
Hootiez28's Avatar
Are you just running a stock converter?
Old May 23, 2009 | 06:51 PM
bombebomb's Avatar
yes
Old May 23, 2009 | 08:24 PM
96SSIndeed's Avatar
lol at !urine
Old May 23, 2009 | 08:31 PM
Josh-'04 GTO's Avatar
Wow I'll second that. Stock heads are choking that engine big time. Also, I didn't see a tune in that mod list. That could be a significant amount of power lost...
Old May 23, 2009 | 08:39 PM
bombebomb's Avatar
Its tuned, mail order.
Old May 23, 2009 | 09:36 PM
Z-RATED94's Avatar
What was the DA? I'm not bashing, but somethings not right.
Old May 23, 2009 | 10:18 PM
bombebomb's Avatar
Not a pro racer but I am looking at it on dragtimes.com and it says for 9:53 (ran at 9:27)
at 9:53 it was 68 degrees, 58% humidity, 30.12 DA (if that sounds all wrong, sorry).
The car was not running 110% but the small kinks that are in it should not effect it "to much".
Old May 23, 2009 | 11:17 PM
115 MPH on stock unported heads..... doesn't sound too bad to me. Big problem with the ET is the weak 60-ft. Once he gets it launched, it picks up respectable MPH over the 2nd 1/2 of the track. Stock converter may explain the weak 1/8th.
How big is the cam?
30.12"Hg is the barometric pressure, not the density altitude.
Old May 23, 2009 | 11:40 PM
bombebomb's Avatar
How big is the cam?
231/239 571 intake lift, .587 exhaust lift.
Does 1445 sound more like the DA?
Yeah, the 1400~ rpm launches are not to quick.
For those who do not sit in here all day reading every little post like some of us (me lol), the reason for the abnormally large cam on stock heads is because heads are in the plans, I just did not have the cash and was not changing cams twice. Also nitrous is in the cards.
Old May 24, 2009 | 12:07 AM
Density altitude is expressed in "feet" and reflects a combination of the barometric pressure, the air temperature and the humidity.
Old May 24, 2009 | 12:21 AM
bombebomb's Avatar
Track Elevation: 744
Air temperature: 68.0
Barometric Pressure: 30.12
Relative Humidty: 56%
Density Altitude: 1445 feet
Relative Density: 95.84 %
There you guys go with some info hehe.
Old May 25, 2009 | 11:45 AM
slowride94z's Avatar
nice, time for some more hook
