TPS sensor and IAC sensor
Old Oct 2, 2005 | 10:22 PM
flusz28's Avatar
I would like to try and clean this two sensors if they are dirty when i pull them off. will this hurt them at all wiping them off? do i have to work bout them being out of adjustment taking them off or anything?
Old Oct 2, 2005 | 11:05 PM
Re: TPS sensor and IAC sensor
The TPS sensor is totally enclosed.... there is nothing to clean. Its a simply rheostat that varies the resistance as the throttle shaft turns.
The IAC motor is not a "sensor".... its an actuator - a small motor that moves a pintle in and out in tiny steps. The pintle should not be moved by hand, or you could damage the stepper motor. You also don't want to get liquid inside the body, where it could damage the stepper motor windings. Hold the pintle pointed down, and spray it with throttle body cleaner or brake cleaner to knock off any carbon on the pintle. You can brush the pintle lightly, or dampen a Q-tip with the cleaner and wipe it gently. Then make sure you clean the passage that the pintle fits into. If you have the TB off, you could remove the bottom plate and clean the passages. But you need a new gasket to reassemble it.
Old Oct 3, 2005 | 10:00 AM
flusz28's Avatar
i think i might just replace the sensors then. since the car sits alot and the car went through alot of time running rich and stuff those sensors could be worn out. well once i replaced the fuel pump my car was back to normal Injuneer. man the blower pulls so hard i love it. as soon as they tuned it the blower was louder and the bov. i love it.. i replaced the map sensor for the heck of it the other day. thanks for all you help.
Old Oct 3, 2005 | 10:25 AM
Daniel6718's Avatar
can you clean a map censor? my cam is tuned and it reads that i have too low intake vacume...and my maf says it isnt readin correctly...i think there related bc my maf is new
Aug 24, 2015 06:41 AM
350350
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
Noct
Jul 14, 2015 01:18 AM
