TPS sensor?
Old Sep 27, 2008 | 01:29 PM
henryz28's Avatar
TPS sensor?
I just got my car back together and it has a bad idle. I unplug the TPS than plug it back in and the Idle will clear up a lot but not all the way. Is this a sign of a bad TPS. Thanks
Old Sep 27, 2008 | 01:37 PM
Red_94Formula's Avatar
With that sensor unplugged your car is going into limp mode which bypasses a few sensors. The best thing to do is scan your car with LT1 edit and see if your stepping is too high on your TPS and go from there.
Old Sep 27, 2008 | 01:51 PM
henryz28's Avatar
When I first start the car Idle is at about 800rpm and bouncing then I unhook the TPS and the Idle is the same but once I plug the TPS back in the idle jumps to about 1200 and bounces around a little.
Old Sep 27, 2008 | 02:54 PM
NukeFPE's Avatar
When was the last time you cleaned your IAC & MAF?
Old Sep 27, 2008 | 03:27 PM
Unplugging stuff is not the way to test. A scanner will easily tell you if the TPS is ok. Don't have a scanner? Buy one and learn how to use it. You can't troubleshoot a modern car without one.
Old Sep 27, 2008 | 05:26 PM
henryz28's Avatar
Are you talking about a regular obd2 scanner. I scanned it and only get a p1642 which is for the fans; I think, but the fans do come on.
Old Sep 27, 2008 | 06:13 PM
henryz28's Avatar
Maf was cleaned not too long ago but I just removed the IAC and it is black. What should I use to clean it?
Searched and found that the maf cleaner will work.
Old Sep 27, 2008 | 07:36 PM
henryz28's Avatar
Ok I cleaned the maf and the IAC. Then I started it and the Idle was high like 1500rpms. And a new code came up p0122.
Old Sep 27, 2008 | 08:25 PM
Green96Z's Avatar
P0122 Code - Throttle Position Sensor/Switch A Circuit Low Input
Have you properly adjusted the TPS?
http://www.golenengineservice.com/html/tps.html
Old Sep 27, 2008 | 10:32 PM
henryz28's Avatar
Thanks green96z I did do that to the TPS when I put the 58mm in but I did not check the volts. Nor did I make sure the blades were set correctly. Ill try that next but I think I set it correctly by luck because when I had it set wrong the trans would shift hard as hell. It did not have this problem a year ago it ran fine but then I started to have ignition problems so I changed the plugs,opti,wires and had the coil and ICM tested. Got it all together and now I have a high/low Idle with surging. I have not driven it but when I rev it in park it sounds good; a lot stronger than ever.
Old Sep 29, 2008 | 12:50 AM
henryz28's Avatar
Tested and reset the TPS and TB blades. But did not change my surging problem. I think I got the P0122 because I unpluged the sensor. The sensor is giving me the correct readings; 0% throttle is .68v and as I open the blades it increaces to 4.92v stedaly. So I think that part is good. The Idle is now normal but it continues to surge. I did buy a cheap cap from ebay here it is.http://cgi.ebay.com/ebaymotors/ws/eB...m=160284222696
I thought the cap/rotor was 2 caps and the rotor. I only got the main cap and the rotor not the cap that the opti wiring plugs into. Any ways I think I am going to have GM check it out and tell me whats wrong.
Old Sep 29, 2008 | 07:57 PM
There is no second cap. The main body of the Opti is the back 1/2 and contains the optical sensor and the harness connector. The cap is the front 1/2 with the coil and plug wire towers. You only get both parts if you buy a complete Opti. A generic cap or complete Opti from eBay is a major risk.
Appears you have a code reader, not a true scanner. Best bet is computer software and a cable, allowing you to read the sensors and calculated PCM parameters directly. AutoTap is one example of OBD-II scan software.
Old Sep 30, 2008 | 01:45 AM
henryz28's Avatar
Thanks I was sure my cheap code reader was not what shoebox mentioned. Looks like its $199 for the kit;I will be ordering on of them soon.
Old Sep 30, 2008 | 03:30 AM
SS RRR's Avatar
Hrm... after putting the solid roller stroker in my car I did not have to reposition the blades at all. It takes a bit for the PCM to learn if it has been unplugged, but does clear up and idles fine at 1150rpm after a week of daily driving.
Old Sep 30, 2008 | 06:20 PM
maverickmk's Avatar
looks like a good kit
