tps sensor
Old Oct 22, 2004 | 03:38 PM
ONELOUDKAR's Avatar
tps sensor
Dont you guys use an ohm meter to set your tps? Which wires are you suppose to prob on it, there are 3 alltogether correct? Do you use probe two with some pins and get your readings from there or what? Meter has to be set on Ohm right?
Mike
Old Oct 22, 2004 | 03:41 PM
Zeueses 97 RamAir's Avatar
Re: tps sensor
what colors are they Im at work now ill tell you ...
FredM
Aug 14, 2015 01:49 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
