TPS @ 32% with car off?!?!
Old Sep 9, 2005 | 08:45 PM
firetird's Avatar
the TPS volts are reading at ~1.9v. these values are when the ignition is on but the car is off. i am going to get some IAC counts to see where they are at when the car is on and idling. is my TPS reading these values bc it needs to be slotted? i have replaced the sensor so i know its good and i have adjusted the stop screw so that its not interferring with the throttlebody. Any ideas?
TIA
Bobby
Old Sep 10, 2005 | 12:31 AM
Re: TPS @ 32% with car off?!?!
The TPS voltage needs to be between 0.20-0.80 Volts. If you're getting 1.9V, something is screwed up. I don't think "slotting" it will allow you to make that much correction. If the snesor is new, may be a wiring problem. First check to see if you have 5V between the gray and the black wires. Are you sure you have the slot in the sensor correctly indexed to the flats on the shaft?
Old Sep 10, 2005 | 03:15 PM
firetird's Avatar
thanks for the tips but i went ahead and slotted the mounting holes on the TPS and it dropped the voltage down to ~.7 and it shows 0% throttle when i start the car now. i didnt think that slotting the holes would bring the voltage down that much but it did and suprisingly, i could have slotted quite a bit more!
thanks
Bobby
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
