TPIS long tube headers?
Old Jan 26, 2004 | 02:24 PM
Z28RV's Avatar
i just say these on TByrne.com, i assume its a new product. they say 25 to 30 rwhp, and theyre expensive too. Does anyone know about these headers
Old Jan 28, 2004 | 11:36 AM
LT4Firehawk's Avatar
I've researched these quite a bit. They have been around a while, but since they are a little more expensive they are less popular. The benefits are that they have a y-pipe available that will bolt right up to the 96-97 cat-back, they are supposed to be designed so you can use standard exhaust manifold bolts, and they are also supposed to be a little bit better for ground clearance than the Hooker/JetHot longtubes. The drawbacks, a little higher cost and no emissions fittings. Honestly though, considering you can get the coated headers and offroad y-pipe for under $900 and then install them yourself, I think it is not that much more than buying Jet-Hots and getting a shop to fab up a proper fitting y-pipe.
Old Jan 28, 2004 | 11:41 AM
SloLt1Z's Avatar
A freind of mine has a set on his 93 383 formula. They where easier to install then the hookers, that about the only advantange I know of.
Old Jan 28, 2004 | 08:32 PM
bad96firechikin's Avatar
I used to have them on my '96 T/A. I loved them, the install was rediculously easy, however, I did have some problems with the steering linkage that req'd me to dimple a tube Ground clearance is good, install is good, power is good, I didn't like the slip on collector flanges. This made it damn near impossible to remove the y-pipe. They're a great header, but honestly, I've gotta say I like my Jet Hots better. The TPIS headers would contact my steering shaft and lock the wheel up under hard acceleration (new stock motor mounts). I ultimately had to goto solids w/ these headers.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
