Check Gages light coming on after 3500RPM
Old Jan 28, 2004 | 07:33 PM
indieaz's Avatar
Was test driving my camaro tonight (having some other issues i was driving it to diagnose). Anyways, alf of a sudden tonight when i hit 3500+ RPM the check gages light comes on. Gages all seem fine (other than oil gage only reading about 35 pounds under WOT since my cam swap...but based on other threads i used this is pretty common and isn't a true indicationt due to location of oil pump on cam'd cars...correct me if i'm wrong as oil level etc. all seem fine). So is there any reason the check gages light would come on?
Old Jan 28, 2004 | 08:04 PM
bad96firechikin's Avatar
35PSI at over 3500 RPM?!?!? I have a cammed car, and at anything but idle I run at about 75 - 80 PSI. You've got something wrong.
Old Jan 28, 2004 | 08:40 PM
StoneRhino's Avatar
I could be wrong, but I wouldn't think putting a new cam in would lower your oil pressure.
David Dorris
Jan 17, 2015 08:10 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
ro2207
Dec 4, 2014 06:18 PM
blac94Z
Dec 2, 2014 12:09 PM
