tpis afr head info
Old Jan 28, 2007 | 07:47 PM
hotheadbuddy's Avatar
Question tpis afr head info
ok im in the middle of assemblying a 396 lt1 with tpis afr heads i just bolted the first head on and after cleaning the second head before install i noticed they have numbers in the combustion chambers 1 3 5 7 and im sure on the head ive installed there numbered 2 4 6 8 i am a tech for gm and know there is not a right and left head they are the same. am i missing somthing and need to swap them to the other side or am i ok. or should i contact tpis for more info on this thanks for all your help.
Old Jan 28, 2007 | 07:53 PM
seawolf06's Avatar
There is a difference because of the coolant bypass hose which should be in the back.
Old Jan 28, 2007 | 08:06 PM
MaxLean's Avatar
Negative. Most, if not all, heads for LT1s have the holes on both ends and the unused ones are plugged. I've never heard of a left/right specific head for a SBC.
Scott
Old Jan 28, 2007 | 08:19 PM
thats what i thought there are identical holes on both heads . the coolant pipe goes in the back and the front holes are pluged but these heads came with no plugs which is fine i just did not want to be over looking anything with this buildup. so should i be ok? thanks again for all you help.
Old Jan 28, 2007 | 08:22 PM
seawolf06's Avatar
Ok, I got my head with plugs and that's the only reason I can think that they would have them numbered.
Old Jan 28, 2007 | 10:43 PM
rskrause's Avatar
Moderator
The valves also have numbers? That's how you tell which valve goes in each specific location.
Rich
Old Jan 29, 2007 | 06:22 AM
thank you for all your input.
Old Feb 3, 2007 | 09:47 PM
Heat Seeker WS6's Avatar
I also have TPiS/AFR 195cc heads and I recall them being numbered as well. We put the heads on the corosponding sides. Its been 42K miles since and no problems with them.
Highlander
Jan 12, 2020 02:13 PM
parkers Z28
Mar 11, 2016 08:14 PM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
Highlander
Aug 9, 2002 02:30 AM
