Total cost for your 383 stroker?
Old May 29, 2004 | 02:41 PM
stang_killa94's Avatar
What should i expect my grand total to be to rebuild my lt1 block into a 383 stroker?
Old May 29, 2004 | 03:16 PM
rskrause's Avatar
Moderator
Re: Total cost for your 383 stroker?
Too many variables to give a meaningful answer. A high quality shortblock will be in the $6,000 range and a "basic" motor could be built for maybe half of that though, if that's any help. Keep in mind, that's just referring to the shortblock. You still need heads, a valvetrain, and a supporting cast (mods to the drivetrain, suspension, brakes, fuel system, programming, etc.) depending what you have in mind
Rich Krause
Old May 29, 2004 | 03:28 PM
blazzinbird's Avatar
a friend of mine payed over 7k
Old May 29, 2004 | 03:32 PM
1984camaroz28's Avatar
with the supercharger i will have close to 9 into it
Old May 29, 2004 | 03:34 PM
WOW
I was hoping i could get all the work done to my stock block, get the stroker kit for 2,XXX, hot cam kit, and my stock heads ported. Will that work?
Old May 29, 2004 | 05:52 PM
flyinZ's Avatar
If your gonna go with the stroker kit, I wouldn't go with such a weak cam...Id end up goin' with a custom ground cam, or anything bigger than the Hotcam...heh
I've got over $6k in mine...It just depends on who does your work, and where ya get your parts..
Old May 29, 2004 | 05:56 PM
BadAssed93Z's Avatar
im only about 7k into mine but im almost done,
just the little stuff left like timing chain, wp, new opti, suspension, transmission, rear end.
you know the basics.
Old May 29, 2004 | 06:21 PM
simple's Avatar
and your **** is still slow
Old May 29, 2004 | 06:49 PM
neil350's Avatar
Starting from scatrch, a complete long block can run you from $4-6K on average. Thats machine work, internals, heads, valve train and assembly. Its not cheap at all, most people do h/c then do a short block a little down the road.
Old May 29, 2004 | 06:56 PM
flyinZ's Avatar
You'll think that, when your seein' my tail lights old man...
Bring it..
Old May 29, 2004 | 08:10 PM
stereomandan's Avatar
Looks like the average is about $6-7k. Sounds worth it to me. Much cheaper than a new car, and a heck of a lot more impressive when complete.
If my LT1 ever blows up, I'll probably be looking at a 383 as a replacement. I hope that's a long ways off though. I have a lot more mods to do...
Dan
smoknta
Aug 27, 2015 05:07 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
alphaauto
Jul 26, 2015 04:40 PM
13qtr
Jul 19, 2015 05:30 PM
