Torquin Heads
Old Apr 23, 2005 | 12:52 AM
c0rey's Avatar
Torquin Heads
Hey I was wondering if someone has a picture or veiw of the tq sequence of the heads on a lt1. Also toque specs as well. Thank You.
Old Apr 23, 2005 | 01:59 AM
BLinindoll's Avatar
Re: Torquin Heads
65 ft.lbs. The only picture I can find for the torque sequence in on a site that you need and username and password to get on. Sorry.
Old Apr 23, 2005 | 02:07 AM
J96Z's Avatar
Re: Torquin Heads
The torque sequence is in the Chiltons. My ARP bolts said to torque aluminum heads to 60 lbs and cast iron heads to 65 lbs.
Old Apr 23, 2005 | 07:33 AM
Re: Torquin Heads
http://www.afrashteh.com/guide/head.jpg
Old Apr 23, 2005 | 08:29 AM
c0rey's Avatar
Re: Torquin Heads
So I dont need to toque them at different specs like 3 times. Just what ive heard like do all of them at 15, 30, 65
Old Apr 23, 2005 | 09:07 AM
matLT1's Avatar
Re: Torquin Heads
To the best of my knowledge you are supposed to "sneak" up on the torque spec so you don't stretch the bolt and also distribute the load over the gasket evenly while tightening.
Old Apr 23, 2005 | 10:22 AM
texasTA's Avatar
Re: Torquin Heads
DO NOT torque them in one sequence at 60 ft lbs. You need to go through them a couple times. Torqueing them to much on the intitial go through can cause the gasket to not "set" correctly and can cause bolts to snap or even damage the head.
When we torqued my little brother's heads on his cammed 95 Formula, we followed the torque sequence and torqued first at 30 ftlbs, then another pass at 45 ftlbs, then again at 55 ftlbs and finally finished them up at 60 ftlbs.
And I am not sure on that final torque setting of 60 ftlbs, it could have been 65 ftlbs. I just don't have my chiltons in front of me to verify what the final torque down value is.
Old Apr 23, 2005 | 11:21 AM
CamaroBoy96Z28's Avatar
Re: Torquin Heads
I did 30/45/65. Definitely dont do it all in one pass.
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
