Torque values for LT1 alum. head rocker studs?
Old Apr 14, 2007 | 07:56 PM
hogs's Avatar
Can someone tell me what the torque values are for the rocker studs in the alum. heads?
Old Apr 14, 2007 | 07:58 PM
VK's Avatar
VK
50 ft/lbs total. 25 starting, then finish it with 50.
Old Apr 15, 2007 | 11:41 AM
hogs's Avatar
Locite on rocker studs blue 242 or red??
Could you guys let me know along with putting Thread sealer on the bottom of the studs ARP should I use blue 242 or red not sure of the number just on the top of the threads to lock them in Seems from the factory there was red of some sort at the top of the old studs ...unless that was to install the steel inserts for the studs in the heads?
Thanks Chris
Old Apr 15, 2007 | 11:44 AM
VK's Avatar
VK
ABSOLUTLY NO locktight on rocker studs! W/ alum. heads you'll damaged the heads. No need for thread sealer either.
Old Apr 15, 2007 | 12:28 PM
hogs's Avatar
Thanks about the locitie but there is Steel inserts I guess GM used RED when they install them, Not sure why You say it would damage the heads since they are going into steel threads....
Anyways Llyod told me to use Thread sealer as when he ports the heads a few of the stud holes get opened up into the intake ports.. So I guess thats why he says to use Thread sealer...??
any thing else you can add?
Chris
Old Apr 15, 2007 | 12:38 PM
VK's Avatar
VK
Didn't know you had ported heads, yes you'll need thread sealer then, the kind to use when sealing waterjacket threads on some of the head bolts.
GM used heil-a-coils on the heads for the rocker studs threads, if you use locitie it will ripe the heil-a-coil out and you'll have the same issue another member has hand on this board lately... its not fun. No other tips, you should be set.
Old Apr 15, 2007 | 12:53 PM
hogs's Avatar
Thanks alot,
Sorry My mistake I never told ya I had Llyod HEads on that...
Thanks again...
Chris
Old Apr 15, 2007 | 01:23 PM
OBE1 95Z28's Avatar
I would coat the threads with teflon thread sealer as the studs could protrude into the intake runners.
Old Apr 15, 2007 | 01:27 PM
VK's Avatar
VK
Your correct, i was thinking he had a set of stock lt1 heads. You need some major ported heads to have the rocker studs holes in the intake runners. Even if you can't SEE the holes doesn't mean you dont have them... when your pushing as much air through an engine as it takes to produce as much power as we are getting these days, even the smallest hole can cause undesired effects.
Old Apr 15, 2007 | 03:39 PM
hogs's Avatar
Yup all is done coated all the studs, Now on to the heads same thing coat them bolts as well, Plus water pump bolts I guess...
Old Apr 18, 2007 | 11:54 PM
SStrokerAce's Avatar
I wanna say last set i installed said 55ft lbs with ARP lube or sealant, and yes you need that on the intake studs if the heads have been ported.
Bret
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
alphaauto
Jan 23, 2015 07:42 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
