Torque spec on LT1 Intake Manifold?
Old Mar 13, 2007 | 04:57 PM
CrazyLT1's Avatar
Hey guys,
Just wonderin how many ft. lbs. of torque to put the bolts at for the intake manifold on an LT1.
thanx in advance...
Old Mar 13, 2007 | 05:07 PM
transAMdriv3r's Avatar
on shoe boxes site it says 71 lb. in. first pass
35 lb. ft. 2nd pass
Old Mar 13, 2007 | 07:32 PM
SS RRR's Avatar
15ft lbs the first pass
35ft lbs the second pass
Old Mar 13, 2007 | 09:06 PM
jclark311's Avatar
Thats 75 inch lbs, 35 ft lbs
Old Mar 13, 2007 | 09:39 PM
35 lb. ft. 2nd pass
...and that's right from the "book".
Old May 7, 2008 | 11:53 AM
JJAPHIPPS22's Avatar
If you make the first pass 71 ft. lb. how can a second pass of 35 ft. lbs. do anything?
Old May 7, 2008 | 01:00 PM
RyanD's Avatar
Old May 7, 2008 | 04:55 PM
Thanks for the clarification
Old May 7, 2008 | 06:14 PM
30696bird's Avatar
My intake is torqued to..... ?? I know many will tell you it's important to torque it but I NEVER do. On a composite intake I would but on an aluminum or iron one "I" don't think it's really necessary. ALL of the bottom end and the heads I torque but not the intake. according to the "book" you SHOULD torque damn near everything. Such as, plugs, headers, water pump bolts, and many more but do any of us follow the book? Shame on me...I know I don't.
Old May 7, 2008 | 07:53 PM
SS RRR's Avatar
If you can get the bolts pretty much torqued consistently then I don't see it as a problem, but if not then you stand a good chance of warping the intake. Do you at least torque the bolts down in a sequence (inside-out)?
Old May 7, 2008 | 08:27 PM
30696bird's Avatar
Yes, I always do that to make sure the gasket seats properly. After you work on cars for a while (15 years+, I'm 32) you kinda get a feel for how tight they need to be. I have never had a problem.
Old May 7, 2008 | 10:28 PM
SS RRR's Avatar
I read ya. I've never trusted myself though.
ModdedNerd
Dec 14, 2014 10:28 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
