Timing chain woes
Old May 7, 2008 | 07:27 PM
1963SS's Avatar
Timing chain woes
Hey guys, I have all my parts from Summit and I was looking at what I ordered. I must have read something wrong on one of the posts. I have a 1995 Impala and need a timing chain. I don't need the water pump drive because I'm electric. Summit sent me a Cloyes 3157. There is no provision to drive the opti off the cam gear. It sure appears that I've ordered the wrong part. Is there a true roller timing chain set that will work that doesn't cost and arm and a leg. A single roller would be best because I really don't want to grind on the front cover. Does anyone have part numbers for what I need.
Thanks and have a great day. --Bill--
Old May 7, 2008 | 10:40 PM
I'm confused. You should have a vented opti. It drives off the cam dowel pin. So, the gear has really nothing to do with it.
A 3157 is just a single rather than a double roller. I don't see why it would not work. I think others have used it.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
