Torque converter questions?
Old Apr 1, 2004 | 10:10 AM
JustAnotherGuy's Avatar
im going to be doing a Head/cam swap sometime this summer.
and I was wondering if it would be ok to run the stock TQ with the XE224/230 112LSA for a few months.
and what TQ should I get to use with that cam. This is just a street car it will probably never see the track but maybe 1 or 2 times a yr.
thanks for any help
-Matt.
Old Apr 1, 2004 | 10:42 AM
americanmusscle's Avatar
Get a vigilante torque converter about 2800/3000 stall and youll be fine.
Old Apr 1, 2004 | 11:33 AM
badazzcamaro97's Avatar
I would suggest the same
Old Apr 1, 2004 | 11:57 AM
Brandon94Z28's Avatar
I just put in a 227/233 cam. I have a 2800 stall waiting to go on after I get the z out for spring. With the stock stall my car feels like a slug, no power off the line. I would def get a higher stall.
Brandon
Old Apr 1, 2004 | 11:59 AM
95_Blk_Z28's Avatar
Where is the best place to buy a 2800 stall vigilante torque converter for a decent price? I know they're expensive, but where is the cheapest place. I've been looking to get one as well. Also what's the difference between a lock-up and a non-lockup Torque Converter?
Old Apr 1, 2004 | 12:01 PM
brandboZ28's Avatar
Im also running the 227/233 but with a 3500 stall. Before, the car felt fine but now that Ive done the converter, I have seen the light. My car ran fine through the stock converter although it never will again.
Old Apr 1, 2004 | 12:10 PM
thanks for the replies.
i was just makin sure it would be ok to run on the stock converte for a bit.
JW but are the SLP torque converters any good ?
Old Apr 1, 2004 | 12:14 PM
The 2800 stall I have waiting to go in is an slp. I thought I would give it a shot since my old 94z had the 2400 slp stall and ran really well.
Brandon
Old Apr 1, 2004 | 12:33 PM
95_Blk_Z28's Avatar
Are slp torque converters as good as vigilante's? Also like I mentioned above, does anyone know the difference between a lockup and a non-lockup Torque converter? Thanks!
Old Apr 1, 2004 | 12:35 PM
I do know that a lock up will give you better gas mileage, but I don't know anything else.
Old Apr 1, 2004 | 01:59 PM
LS1_03's Avatar
When a converter "locks up" it no longer slips. It acts as a car with a clutch.
Old Apr 1, 2004 | 02:30 PM
BlackIce's Avatar
i would suggest at least a 3200, i have a 3200 in my daily driver which i drive every day and i would go a little bit bigger if i had the chance.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
ChrisFrez
Feb 15, 2015 07:49 AM
Collector Car
Dec 17, 2014 01:12 PM
squarehead
Nov 21, 2014 08:02 PM
RedLineRev
Jan 23, 2003 03:51 PM
